Forum
Suzuki Jimny
Jimny Chat
What comes standard and what should I fit after-market?
BigJimnyMeet 2024
StevenMark
Topic Author
Visitor
10 Aug 2018 10:04 #194973
by StevenMark
Thanks for that. But couldn't I get the Jimmy lifted to match their clearance?
Sent from my SM-A520F using Tapatalk
Lambert
Offline
Moderator
The quickest Jimny in Harrogate...(that I own)
Thank you received: 1759
10 Aug 2018 10:34 #194974
StevenMark wrote: Thanks for that. But couldn't I get the Jimmy lifted to match their clearance?
Yes but a lift in and of itself will not generate more clearance other than improving the approach, departure and ramp angles. What it will do is give some more clearance for bigger tyres which is the only relatively affordable way of getting ground clearance under the diffs. It has some down sides though. There is a limit even on a very lifted Jimny on how big a tyre will fit before you are butchering the body. There is also a limit on the gearing without significant expense in fitting lobster boxes and lower diff sets. Then you run out of power with the 1.3 and have to swap in a 1.6 or as available a 1.8 or even a diesel. All of which essentially gets a Jimny to the starting point of a defender or cruiser. If you then carry out the same mods to one of those a Jimny no matter how much we may want it to will ever compete.
The trick is to make use of a Jimny to fit through obstacles too small or soft for the big tanks to deal with. I can get places in my road going Jimny that mates with lifted 80 series cruisers just can't simply because I have access to different lines through obstacles than they do and it really winds them up something shocking!
The following user(s) said Thank You: StevenMark
TomDK
Visitor
10 Aug 2018 10:35 #194975
by TomDK
It would be pretty pointless? You would need 33-35" tyres. So why not just get a bigger 4x4 then?
Thank you received: 728
10 Aug 2018 20:40 #195002
by kirkynut
The benefit of a Jimny is you can really modify it to make it great off road for the starting price of a standard version of many of the aforementioned 4x4's. It will be more capable in the end.
Just don't worry about the fact you are pumping money into something that is not gaining the same in value!
Lambert
Offline
Moderator
10 Aug 2018 20:57 #195006
You can't put a Jimny however modified against a land cruiser with similar modifications and expect it to compete head to head it's like comparing apples to coal shovels, both are very good in their own right but one can't do what the other can.
Forum
Suzuki Jimny
Jimny Chat
Time to create page: 0.110 seconds
