BigJimnyMeet 2024
Re:isuzu 1.5td 4ec1 engine conversion
- MadsV
- Visitor
21 Nov 2018 06:48 #197879
by MadsV
Replied by MadsV on topic isuzu 1.5td 4ec1 engine conversion
Looks great, I see you have great tools and skills for fabricating parts
- Thank you received: 1
21 Nov 2018 12:00 #197906
by Jefferies
Replied by Jefferies on topic isuzu 1.5td 4ec1 engine conversion
Well i'm an automotive engineer and have free access to a CAD package for the design work, and fortunately i work at a place where i can use the kit for my own purposes and we've got some really good contacts to get small stuff made cheap/for free. Should have a nice CNC machined billet spacer for the gearstick coming today/tomorrow
*any of the ratty welding is mine, all the lovely neat welding is our fabricator's
Oh god i love ebay, and the piece price of mass produced OEM car parts!! Just bought a brand new radiator for a mk1 renault Megane for £22 including delivery. I chose this one as it should fit nicely in the available space and it has both hose spigots on the near side. They need to be on that side really for a neat install, avoiding having a great big top hose cutting across in front of the engine.
I also bought a brand new genuine ford intercooler that isn't a big wide one for £17 including delivery!!!! This one is more of a punt and hopefully i'll be able t work it in somewhere nice.
21 Nov 2018 12:18 #197909
by Jefferies
Just did a quick calc and the new gearstick should give me the choice between a maximum leverage ratio of 4.82 and a min of 3.69. The standard gearstick had a ratio of roughly 6.29 giving a throw of 122mm. This means that the throw of the new gear knob will be reduced by between 24% and 41% (also giving an equivalent increase in required gearstick effort). I've not driven a vauxhall Omega but i've seen anecdotal evidence that the standard gear change is sloppy and not very nice. With this in mind hopefully the new setup will be tune-able to a much nicer feel whilst giving me the 'defender' look i was going for.
22 Nov 2018 22:26 #198028
by Jefferies
Gearstick is ready for a trial fit so I can make sure it works properly and put a bend in the bar to get the gear knob in the right place. Quite chuffed with the spacer block, especially as it was FOC.
Also had the two odd ends of the prop shaft machined so that they spigot together. Just need a bit of cleaning up and then welding.
- Thank you received: 177
22 Nov 2018 22:49 #198029
by gv42
Replied by gv42 on topic isuzu 1.5td 4ec1 engine conversion
looking good,
23 Nov 2018 18:35 #198062
Replied by Riccy on topic isuzu 1.5td 4ec1 engine conversion
Yes its all good there. some proper engineering going into this project
24 Nov 2018 17:36 #198107
by Jefferies
19 Feb 2019 21:47 #203497
by Jefferies
- Venter
- Visitor
20 Feb 2019 11:22 #203526
by Venter
Replied by Venter on topic isuzu 1.5td 4ec1 engine conversion
Looking good. You have to make that bend yourself or do the rods come like that?
20 Feb 2019 17:58 #203560
by Jefferies
No i got someone to do it for me who's got oxy acetylene as it needed a fair bit of heat.
The following user(s) said Thank You: Venter
21 Jan 2020 14:54 - 21 Jan 2020 15:12 #217484
by Jefferies
Right, It's been ages again since i last posted but i have intermittently been working on the Jimny. Haven't quite had it running yet but isn't far off now. The work i've done since my last post is:
Test fitted the gearstick. Works a treat, just the amount of throw i was after and a really nice feel to it.
Had the prop shortened
Relocated alternator, new water pump, painted pulley, sorted new belt and tensioner. Took a bit of messing about and buying the wrong sized belt but got there in the end. I'll remake the bracket in the future but it's functional for now.
Repositioned vac pump so drain would clear heat shield. I had to remove/disassemble the pump so i could accurately measure the backplate on a CMM and use this data to design a new one on CAD albeit with a 2nd set of mounting holes rotated by 25 degrees. My boss cut it out for me on the CNC mill and it works a treat
Fitted new hoses to vac pump and replaced all the banjo fittings. I'll probably tap into the oil feed in the future for a pressure gauge on the dash.
Tarted up heat shields as new ones aren't available. This involved snapping some bolts in the manifold which was fun to sort out
Fitted fuel filter housing. Made a new bracket that picked up on some existing captive nuts in the wing
New thermostat and changed temperature gauge sender for one that is compatible with the jimny
Spaced out thrust bearing as i'm using a single mass flywheel. Also made new copper pipe to fit and added a flexi pipe from the bellhousing to the bulkhead pipe coming from the master cylinder
New sump and bellhousing closure plate. I'm hoping that the standard new sump will clear the steering rod at full bump but we'll see...
Bracket for header tank. This allows a header tank from a mk4 Astra to be used
Finding out which temperature sensor to buy was a real pain as the loom in my Jimny had a 3 pin connector for the temperature sensor. 3 pin sensors for JImny's appear to be very difficult to get hold of and therefore expensive. In the end i took a gamble on a cheap 2 pin one from ebay and fortunately it worked perfectly when i bench tested it with the instrument binnacle.
This is the sensor i used, its got an M12x1.5 thread so i had to drill and tap the thermostat housing to accept it
Beforehand i tested the gauge with a potentiometer to see what resistance it required to get the gauge to sit in the normal temperature position
I've also done a load of work on the wiring harness, both deleting what i don't need on the existing stuff and trying to integrate the engine harness for the isuzu engine. I've still got the wiring to finish off plus:
Fit steering pump from mk4 astra and plumb/wire
Finish plumbing coolant system
Fit and wire electric fan. Hopefully should be able to use a renault one that will fit straight to the radiator.
Fill engine and gearbox with oil
Mock up some kind of exhaust (side exit hopefully)
Last edit: 21 Jan 2020 15:12 by Jefferies.
- Thank you received: 1759
22 Jan 2020 06:00 #217517
Replied by Lambert on topic isuzu 1.5td 4ec1 engine conversion
This is going to be able to roll up a mountain on tickover!
Time to create page: 0.313 seconds
