BigJimnyMeet 2024
Re:isuzu 1.5td 4ec1 engine conversion
- Thank you received: 1
31 Oct 2018 23:01 #197221
by Jefferies
Replied by Jefferies on topic isuzu 1.5td 4ec1 engine conversion
Also made a gearbox mount that I think I'm still going to have to modify, im struggling to align the gearbox and transfer box flanges properly. I'm planning on turning up a boss that will bolt to the gearbox output flange that has a hole in the centre that I can put a laser pen in to project the centre axis onto the transfer box flange.
Finished the mod to the steering column
Cleaned up the chassis where the new engine mount brackets will be welded
Shortened the gear linkage and support bracket on the R25 gearbox, was soo easy it was unbelievable
- Thank you received: 1761
01 Nov 2018 04:59 #197224
Replied by Lambert on topic isuzu 1.5td 4ec1 engine conversion
Making good progress there.
05 Nov 2018 17:47 #197340
by Jefferies
11 Nov 2018 21:15 #197590
by Jefferies
16 Nov 2018 19:00 #197704
by Jefferies
Ok so the engine mount brackets on the chassis are painted
And I've ditched the original gearbox mount I made in favour of a new simpler one. The original mount didn't take into account the fact that the engine and gearbox are not coplanar, there is an angular misalignment. Due to the fact that I have mounted the engine vertically the gearbox mount has to take up this angle which is why I made a new one. Just shot a bit of paint on it ready for fitting tomorrow
16 Nov 2018 19:08 #197705
by Jefferies
18 Nov 2018 04:26 #197735
It's fascinating to see how you are overcoming all these little things.
The following user(s) said Thank You: Jefferies
18 Nov 2018 08:52 #197741
by Jefferies
Engine and gearbox are now sat on their own mounts. The engine has ended up slightly off centre towards the off side but only by a small amount. And not enough to be really annoying. If anything it gives me some more room on the near side for the refitting of the alternator and maybe the power steering pump.
Annoyingly I can't use the original mounting method as that used the bolt holes I have picked up on for the engine mount on that side. I may well stick the alternator up high where the ps pump should be and put an electric ps pump on. My daily driver has just let another gearbox go DUE to having a significant remap so after 8 years and 314000 miles I've retired her. It's a mk4 astra 1.7DTI so I think in time it's engine will find it's way into the jimny, along with the elec ps pump, front sports seats, clutch hydraulics.
18 Nov 2018 08:54 #197742
by Jefferies
18 Nov 2018 09:45 #197744
by Jefferies
Here's how i attempted to align the prop flanges. Not perfect but good enough.
There is a little bit of droop now the rubber in the moun5 is compressing but I can pack this out to the correct height
20 Nov 2018 17:55 #197858
by Jefferies
The new gearstick assembly is coming together nicely.
Note that two of the parts have been reused from the original omega gearstick. The fulcrum ball has been removed and had an M14 thread put through it, and the bush retainer for the lower clevis pin has been chopped off and welded to the new gear stick
20 Nov 2018 17:59 #197859
by Jefferies
This is how the throw of the gearstick is adjusted
