New Jimny - UK
- Thank you received: 225
I think that the platform is essentially a Jimny that has been modified only as necessary to integrate the new K15B engine. Even the transfer case shift "lever" I think is only a part of Suzuki's "retro" effort. Looking at the transfer case in the rendering, I don't see any accommodation for a lever. I'm thinking the lever is most likely no more than a 3 position switch, electronically operating the transfer case in place of the dash mounted buttons. It is only a rendering so the reality may be a little different.
While my thinking is that the platform is primarily the same as the current generation, what is impossible to tell (or get information on) is what transmissions are being used. That's what I'm really waiting for. All that is indicated is that it will have a 5 speed manual and 4 speed automatic. Since the K15B apparently has a max torque output of 138 Nm, I'm thinking that at least the automatic may change. The current TW-40E is rated at a max torque input of 114.5 Nm. It just doesn't make sense to me for Suzuki to keep the current AT. I would love to see one of the 03-70 series put behind the new engine but that is going back to the guessing/prediction/hoping game again.
We will all see soon.
- Thank you received: 1754
zukebob wrote: Even the transfer case shift "lever" I think is only a part of Suzuki's "retro" effort. Looking at the transfer case in the rendering, I don't see any accommodation for a lever. I'm thinking the lever is most likely no more than a 3 position switch, electronically operating the transfer case in place of the dash mounted buttons. It is only a rendering so the reality may be a little different.
Good spot, I thought the lever had been photoshopped out of the chassis picture as it does appear in some interior pictures but I am convinced you are correct, electric t-box with "fake" retro lever switch inside. Thanks for the thought
- Thank you received: 328
the existing transfer box has only the one shift actuator so a simple lever front to back via a wire device where the actuator is today would be easy to design.
but for a sales purpose it should be push button.
I have bought SJ's from elderly people who had never dared touch the transfer stick. A lever looks scary for some people actually.
As initially stated, my prediction
- MadsV
- Visitor
- Thank you received: 79
MadsV wrote: Here is one in Chile
I can see an all grip logo there
They could be using the AllGrip pro logo, I can't quite make it out? This video is quite good it explains all the different AllGrip modes
www.suzuki.co.nz/all-grip
This is on Suzukis website:
www.globalsuzuki.com/automobile/lineup/newjimny/index.html
Part time 4WD with low range transfer gear
- Caelite
- Visitor
A guy can dream
Desiris wrote: I think the front prop is hidden behind the centre prop in the picture. There's a chassis view from a different angle in this you tube video at 0.43
If you look at the video 35 seconds in it shows the automatic gear lever and just below it there is a 4x4 selector lever?
- MadsV
- Visitor
Here are the dimensions for your garage....
Jimny SIERRA ( with flared wheel arches)
L 3600 mm, a total width of 1600 mm, a total height of 1715 mm, and a wheelbase of 2250 mm.
Fuel Consumption: (Japanese version so it could be the 660cc version?)
Fuel consumption of the new "Jimny" will be 16.2 km / L for 5-speed MT
For 4-speed AT it will be 13.3 km/ L , specification from WLTP, which is the new fuel consumption standard .
- Thank you received: 260
mlines wrote: Whilst the purists will love it, I think the high street market would expect permanent 4WD such as an Alldrive transmission. I hope for jimny sales that they do offer that in some markets.
That is what I would want.
