BigJimnyMeet 2024
Spring Spacer Help
10 Mar 2018 05:11 #190208
Replied by mlines on topic Re:Spring Spacer Help
Take a close look at the top of the spring in this picture, it is sat in a cutout in the spacer
10 Mar 2018 08:05 #190217
by Busta
Replied by Busta on topic Spring Spacer Help
And equally importantly, the spring seat on the axle has a similar shape and the spring needs to be positioned the same.
- Thank you received: 63
10 Mar 2018 08:43 #190219
by furo
Replied by furo on topic Spring Spacer Help
Thanks guys. I have the Superpro 15mm spacers and there is no cut-out - they are completely uniform all the way round.
- Thank you received: 75
10 Mar 2018 09:14 - 10 Mar 2018 09:21 #190221
by robs5230
standard jimny - for now
Replied by robs5230 on topic Spring Spacer Help
This is the one you needed to cure the lean
www.bits4vits.co.uk/store/spring-spacer-...ng-/-jimny-lean.html
Last edit: 10 Mar 2018 09:21 by robs5230.
10 Mar 2018 17:32 #190232
by furo
18 Mar 2018 15:35 #190571
by furo
Thanks for your help with this folks!
Just to update I bought the 38mm spacer from bits4vits and installed it today (replacing the 15mm superpro spacer in the front). I left the rear superpro spacer in place, and remeasured the distances between the arches and wheels. By my calculations the new spacer has lifted the front drivers side by a further 10mm, and it is now just slightly lower than the passenger side (no difference to the naked eye). There has been absolutely no difference to the rear (rear driver's side is still 10mm lower), so I will leave the rear superpro spacer in.
