BigJimnyMeet 2024
× A place for general chat about the Jimny. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
Kaiser Diff
  • ME13OSE
  • Visitor
  • Visitor
08 Oct 2017 20:21 #184979 by ME13OSE
Kaiser Diff was created by ME13OSE
Got one arriving tomorrow for the front of my Jimmy, anyone got one or had any experience of them?
  • Wokka
  • Visitor
  • Visitor
09 Oct 2017 11:16 #184992 by Wokka
Replied by Wokka on topic Kaiser Diff
Only got 12 hours experience with one in the rear.
I was about to update my other post when I saw this pop up.
Right, install was simple, maybe 3-4 hours all up
First test drive after resetting everything back to factory torque figures, it was an absolute female dog, big bangs on change in direction, constant tick tick tick from the rollers, could feel the car shake when it let go.
Digging a bit into the forums, the Landy boys seem to have similar issues especially in Manual 90's.
It seems (and this is forum opinions, not neccessarily pro's) that the Kaiser diffs tend to be a lot happier in a long wheelbase and backed by an Auto trans
If you're running one in the front, your on road manners shouldn't be compromised, as long as you have manual hubs, how the front will perform off road, I can't help you with
09 Oct 2017 11:20 #184994 by Busta
Replied by Busta on topic Kaiser Diff
Without saying I told you so, that sounds much like a lockrite!
  • Wokka
  • Visitor
  • Visitor
09 Oct 2017 11:58 #184996 by Wokka
I'm big enough to stick my hand up when I've messed up. Waiting on a response back from Jimnybits in case there's some glaringly obvious reason why. if not, it goes back as it doesn't do what it says on the tin, and i substitute locked diffs for more power
  • Wokka
  • Visitor
  • Visitor
09 Oct 2017 11:59 #184997 by Wokka
it was actually worse than a lockrite, hence the contact back with Jimnybits to see if I missed something
  • ME13OSE
  • Visitor
  • Visitor
09 Oct 2017 15:02 #185002 by ME13OSE
Replied by ME13OSE on topic Kaiser Diff
Essentially it should be the same as the Quaife ATB in my track car which operates without any issues, even under race conditions. It's almost the same money as the Quaife to be honest
  • ME13OSE
  • Visitor
  • Visitor
09 Oct 2017 16:33 #185006 by ME13OSE
Wokka wrote: Only got 12 hours experience with one in the rear.
Just out of interest, who set the diff up to the pinion gear? And what method did they use.
09 Oct 2017 17:07 #185007 by Busta
Completely different to a Quaife ATB unfortunately. If Quaife made a diff for the Jimny all our prayers would be answered!
09 Oct 2017 20:34 #185020 by Busta
Wokka wrote: I'm big enough to stick my hand up when I've messed up. Waiting on a response back from Jimnybits in case there's some glaringly obvious reason why. if not, it goes back as it doesn't do what it says on the tin, and i substitute locked diffs for more power
Just reading the Jimnybits site, their description is fairly wide of the mark in terms of how the 'diff' works and the benefits it offers.
"unlike a lockright diff locker, this Kaiser locker will operate as a normal open diff during normal driving" It does not, at any time, operate like a normal open diff. The key feature of an open diff is it splits torque equally between both wheels. In normal driving, this diff sends all the torque to the slowest wheel just like a lockright.
"The Kaiser lockers works by not allowing any one wheel to spin faster than the differential ring gear, so if one wheel looses traction, this wheel will never go faster than the ring gear, hence the power will be transferred to the other wheel. " No it doesn't. It does the opposite- drives the slowest moving wheel at the speed of the ring gear, the other wheel being allowed to 'freewheel' faster than the ring gear. If the driven wheel looses traction, its speed will match the other wheel and both will be driven at the same speed i.e. the diff will lock.
- 100% traction in both wheels Only if they are travelling the same speed or one is spinning. Otherwise it is 100% torque ("traction") to just 1 wheel.
- Exclusive compensation system on curves Um, not really. It just drives the inside wheel because it's the slowest.
- Fully automatic - no surprises
- Safer for driver – no need to switch on / off
Debateable. An open diff is safe as it is very predictable. A diff that puts more stress on one wheel, then locks could never be as predictable, therefore is not really as safe.
- Reduce vehicle wear Compared to an open diff, it doubles the maximum amount of torque that can be transmitted through either half shaft, so there is definitely going to be some increased wear. It is also pushing the car from one side of the axle or the other, not both sides equally like an open diff so that's going to put more stress on the trailing arm bushes
- Does not change vehicle´s originality Yes it does?
So I think you have some grounds for saying it's not as described....
  • 1066Boy
  • Visitor
  • Visitor
10 Oct 2017 06:19 #185031 by 1066Boy
Replied by 1066Boy on topic Kaiser Diff
A mate of mine has one in the rear of his jimny and he loves it. I think a lot depends how its set up. He had a local specialist install his for him and had no problems so far.
  • TomDK
  • Visitor
  • Visitor
10 Oct 2017 06:45 #185034 by TomDK
Replied by TomDK on topic Kaiser Diff
1066Boy wrote: A mate of mine has one in the rear of his jimny and he loves it. I think a lot depends how its set up. He had a local specialist install his for him and had no problems so far.
Had really hoped that a locker for that kind of money would be better than experienced. It should be, an ARB airlocker is the same money, or even a bit cheaper in continental Europe.
Well, hope it all gets sorted somehow, or you get your money back.
10 Oct 2017 09:13 #185044 by maverick
Replied by maverick on topic Kaiser Diff
I have a Kaiser in the Rear Diff in my Jimny, after about 10yrs of Detroit Lockers chewing up Rear Half Shafts every 6months.
I took my donor diff and Kaiser to a reputable garage to fit, he said it was relatively easy (hardest part getting the lower bearings out). With the Detroit Locker I always felt as if there was a "drag" and of course that was joined with the constant LOUD BANGS and Ticks when on tarmac ... since having the Kaiser, the rear end feels lighter and I can cruise of motorways at an easy 70mph. My Kaiser has NONE of the bad symptoms of a Detroit Locker (bangs, clangs, pulling left and right).
The Kaiser is essentially a poor man’s ARB.....
OK, they are not cheap, but easy to fit, no need for air, no need for extra electrics for Air pump ... and to be honest I don't know it’s there, but I DO KNOW it works, as off-road is just like a Detroit Locker.
I was thinking of getting one for the front, but so far, I haven’t since the need.
Hope that Helps?
Brett
Jalapeño, IISY?
The following user(s) said Thank You: ME13OSE, 1066Boy
Time to create page: 0.131 seconds
Powered by Kunena Forum
