BigJimnyMeet 2024
× A place for general chat about the Jimny. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
Swift 1.6vvt engine into a 2007 vvt jimny project
  • 1066Boy
  • Visitor
  • Visitor
15 Feb 2017 17:42 #178033 by 1066Boy
Busta wrote: 1066boy- I was wrong about the rev limiter, I checked this evening. It cuts in at 7,000rpm on the m13a. That's 500rpm past the redline.
Thanks for the update. Mine pulls very well from low revs right through the rev range but stops approximately at 5500rpm.
It never falters at higher revs even around 5000rpm but suddenly at 5500rpm just hits a wall that's why I was asking about
a limiter. Its not really a problem as I very rarely rev it that hard but would like to know why. Any ideas?
  • Riccy
  • Riccy's Avatar Topic Author
  • Banned
  • Banned
  • J999 MNY Bashing around Carlisle
15 Feb 2017 18:41 #178038 by Riccy
Keithy wrote: Just cruising Riccy.....I don't half miss the turbo....it was quieter in the cab! :D
Have a look at these callipers....early Vitara ones......vented discs are from a Diesel Jimny.....haven't warped yet!
I did the brakes prior to gaining more power........I have discs on the rear too.
Everything fitted straight on and improved the situation.
Old calliper is on the floor in that picture.
that looks good, do you know the hub size for the brake discs you use by any chance? mine uses the 108.something (larger) sized centre bore. If they are for a diesel jimny, then they are hopefully the same for me as they were for you. The calipers look a straightforward swap. did you get the discs from a UK supplier?
By the way, i had a closer look at my swift engine and the throttle body is a drive-by-wire electronic type, so probably no great use to me for any improvement in the jimny. it looks like it is slightly larger bore, and the intake manifold is totally different shape.
15 Feb 2017 19:10 #178040 by Keithy
I think mine are 108mm Riccy.
They are genuine ebay parts for around £30
Order a Liana TB from fleabay.... I paid £28 delivered and was pleased at that!
Remove the Jimny manifold and modify it off the engine...easier to clean that way :D
I'll have to check my wife's Vitara to see if it has the same calipers...it has the same pads Mintex MDB1690.
  • Riccy
  • Banned
  • Banned
15 Feb 2017 19:27 - 15 Feb 2017 19:30 #178042 by Riccy
all the jimny diesel discs i can see on fleebay are the same as the solid/un-vented ones i have? are they an aftermarket demon-tweeks type of thing? the disc internal bore is 108.3mm ive found out.
edit... found out they are vented on later model diesel jims
will have a look for a liana throttle body next...
Last edit: 15 Feb 2017 19:30 by Riccy.
15 Feb 2017 20:55 #178044 by Keithy
No eBay APP ID and/or Cert ID defined in Kunena configurationTry these Riccy
15 Feb 2017 23:16 #178047 by Busta
Try revving it in neutral and see what it does. It seems odd that it would be fine up until 5,500rpm but have nothing after that. If it's reaching the rev limiter you will hear the distinctive 'wa-ba-ba-ba-ba-ba' as the revs cut back.
  • 1066Boy
  • Visitor
  • Visitor
16 Feb 2017 07:12 #178052 by 1066Boy
That was what I was expecting but it don't do the normal rev limit stutter, just refuses to go over 5500rpm.
  • Riccy
  • Banned
  • Banned
18 Mar 2017 19:41 #179369 by Riccy
So today, after much messing around ive started on it (myself actually)...
Old M13A VVT:
And todays progress:
Luckily, work are building a new office/workshop for themselves so was able to persuade the boss to let me do it in there :-)
Now... what i really need are torque settings for the various bits i have taken apart. I know which were the tight buggers, but not what they should be set to?
useful to know torque settings would be:
Intake manifold
exhaust manifold
rocker cover
flywheel
clutch, etc
engine to gearbox bell housing
sump pan
belt tensioner
anything else you think i have missed?!
Thanks all,
Riccy
  • Daniel30
  • Visitor
  • Visitor
18 Mar 2017 19:54 #179370 by Daniel30
Check your PM Riccy :)
18 Mar 2017 21:00 #179378 by Keithy
Way to go Riccy!
18 Mar 2017 21:38 #179381 by Rhinoman
1066Boy wrote: Thanks for the update. Mine pulls very well from low revs right through the rev range but stops approximately at 5500rpm.
Put a scan tool on and watch the O2 sensor reading, if it goes lean then you don't have enough fuel.
The following user(s) said Thank You: 1066Boy
  • Riccy
  • Banned
  • Banned
19 Mar 2017 19:27 #179404 by Riccy
onto day two...
managed to get all the bits needed swapped over onto the 1.6 lump:
Treated some rust with a bit of buzzweld i had left over while i could get at it:
But have come up with a water pump problem, so will need to sort out a new hose tomorrow. Managed to get it fitted back in with exhaust, clutch, etc all back on. just need to sort that pipe, stick inlet manifold back together and plug in wiring again, fluids.
Time to create page: 0.239 seconds
Powered by Kunena Forum
