BigJimnyMeet 2024
× A place for general chat about the Jimny. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
what are the best basic mods
  • TomDK
  • Visitor
  • Visitor
12 May 2016 19:15 #166675 by TomDK
Replied by TomDK on topic what are the best basic mods
darthloachie wrote:
TomDK wrote: As you normally would do. Don't know if I didn't express myself correctly on how the lockright works. But it locks when torque is applied, either forward or in reverse. Meaning roundabouts needs to be with clutch disengaged/down.
sorry but thats a load of rubbish
lockrights work by being locked unless it senses a difference in rotational speed between the two halfshafts (ie going round a corner) when it unlocks with a click (or a very loud clunk if not set up correctly lol)
you don't need to do anything special with the clutch for roundabouts or corners
however on show or ice you can become a drifting god (as Hammond would say)
Sorry. But no. You're very wrong. Just looking at the lockright pretty much explains how it works.
www.offroaders.com/tech/lock-right-locker.htm
  • darthloachie
  • Visitor
  • Visitor
12 May 2016 23:19 #166696 by darthloachie
Replied by darthloachie on topic what are the best basic mods
Having owned a lockright equipped jimny for 6+ years I have never had to dip the clutch to go around a corner or a roundabout,
It will unlock by the act of slowing for a corner thus reducing torque to the locker, A much bigger impact on driving style is the 4-5" lift and no anti roll bar
  • ewanm77
  • Visitor
  • Visitor
12 May 2016 23:26 #166697 by ewanm77
Replied by ewanm77 on topic what are the best basic mods
I've ordered a ball and pin hitch and a light bar. There is a lot of deer around the farm so the more light the better.
13 May 2016 02:08 #166700 by kirkynut
How on earth did we get to suggesting a rear locker for a slightly tricky access road? I'm sure your Jimny will cope exactly as it is now!
If you want to mod it slightly then of course the trickiness of said road could be used as an excuse for spending the money! In which case a 2" lift and some 215/75/15 new mud terrain tyres will be just the ticket! You only need all terrains by the sounds of it but when you look at want and need they are very different things!
  • 1066Boy
  • Visitor
  • Visitor
13 May 2016 05:54 #166703 by 1066Boy
Replied by 1066Boy on topic what are the best basic mods
kirkynut wrote: How on earth did we get to suggesting a rear locker for a slightly tricky access road? I'm sure your Jimny will cope exactly as it is now!
+ 1 :)
  • Venter
  • Visitor
  • Visitor
13 May 2016 17:49 #166738 by Venter
Replied by Venter on topic what are the best basic mods
Well said that man!
  • ewanm77
  • Visitor
  • Visitor
13 May 2016 20:43 #166754 by ewanm77
Looks are important lol Im going to order a 2" lift kit on payday I need new shocks anyway. Then if I decide to start driving harvester tracks then I'll go for more mods
13 May 2016 21:17 #166757 by Busta
Replied by Busta on topic what are the best basic mods
Completely off topic now, but....
A properly set-up lock right is definitely NOT always locked when on the gas. By default it sends all the torque to the slowest moving wheel and allows the faster wheel to 'freewheel'. It only locks when the speed of both wheels is equal.
The bit people struggle to understand is the hole around the diff pins, which is oversized and ramped.
The spacing in the entire system should be set-up such that if the teeth on one side are engaged, the other side has space for the teeth to pass each other. The diff will only lock when there is resistance at each side of the axle and the wheel speeds are the same, at which point the pin will be pushing on both ramps equally and the teeth will engage with both side gears. As soon as traction is re-gained and the load decreases on one side, the pin no longer pushes on the ramp on that side of the diff and the oversize hole allows the side gear to disengage.
It's a very crude system as it cannot balance the torque between wheels like an open diff- it delivers 100% of the torque to the slowest wheel until it slips, at which point drive is sent to both wheels. But it is effective and cheap.
  • jerry
  • Visitor
  • Visitor
18 May 2016 15:47 #166964 by jerry
Replied by jerry on topic what are the best basic mods
All jimnys left the factories more than adequate to do what they were designed to do :ohmy:
19 May 2016 18:33 #167027 by kirkynut
jerry wrote: All jimnys left the factories more than adequate to do what they were designed to do :ohmy:
What was the design brief though?
Time to create page: 0.128 seconds
Powered by Kunena Forum
