Re:The Rat Trap
- Keirravn
- Visitor
- Max Headroom
- Banned
- Thank you received: 217
I reset mine several times by simply disconnecting the battery, but each time I reset it, it would remain off for shorter periods. It finally started to come back on very quickly - within a mile or so of setting off.
I eventually gave in and cx'd the damned thing
- Keirravn
- Visitor
What's CX? I originally thought you meant changed but now I'm not so sure?Max Headroom wrote: Totally with you on that!
Mines comes back right away sadly
- Max Headroom
- Banned
cx = change and cx'd = changed.
You were absolutely correct!
- Keirravn
- Visitor
Got ya! Ha haMax Headroom wrote: Sorry - aviation engineering yuckspeak - I use it at work every day and its a habit.
- Keirravn
- Visitor
I did get all the tail lights working! All electronics now good other than potentially that obd. I'm borrowing a proper reader on Monday so will take it from there.
Kingpin bearings have arrived and I'll order a CV tomorrow and fit it all next weekend if time and weather suits.
Since all my welding (that I know is needed anyway) is done and all my electrical gremlins (I believe) sorted I was able to pop the interior back in which made it feel like a car again
I also sent away the forms to get the V5 and declare it sorn. I decided to be brave and register the colour as green ...
Here's my daughter (the wee one) and the neighbors kid getting their first seat in the Jimny. My daughter peed on the driver's seat about 4 minutes after I fitted it ...
- Thank you received: 475
- Thank you received: 1759
Take all the interior back out including the dashboard and fit 4 plastic bucket seats and a roll cage and give your little one the coolest school run car in the catchment?
- Keirravn
- Visitor
Hmmmmm ...Lambert wrote: Can I make a suggestion?
Better see if it's mot'able before I start with the mods
- Keirravn
- Visitor
The calliper pins must be made of a different metal though as they're seized solid. Not a surprise given the state of the outer disc.
I'll come back to that after it's soaked for a few days. If the weather is ok I'll crack on with the other side tomorrow
- Thank you received: 332
I'm 48, I don't understand.
Edit: Aha, seems I managed to remove them from the topic
Unstuck bolts could be a sign that there have been some servicing done to it..
