Bob! Daily driver/something to play with!
- Visitor
Much better now, need to do a bit of cleaning and tidying up. Next job is to get it up on my little ramps and clean and rust proof what I can reach underneath, it's never going to be as perfect as paying to have it done but hopefully it will help a little, and I'll keep on top of it every winter. Losing one car to terminal rust has taught me lessons!
Bob - 2005 Jimny - standard, for now.....
Planning on changing the belts in Bob. Just figuring out the details as to order the correct belt. Am I right in thinking its a M13A VVT engine in my model, it does have power steering, but it does not have air con. (I've used the wiki page to determine the belts.)
So I can just purchase these through the shop?
Cheers!
Sorry being quiet. Christmas ate my money.
Belts on order soon, also want to change the battery for a new one because it’s been a bit sluggish of late, combining that with the belts I thought I’d cover all bases.
Can anyone recommend a better powered one than would of been in originally? And if so where I can order.
Thanks again gang.
- Max Headroom
- Banned
- Thank you received: 217
eddlane wrote: Christmas ate my money.
I know that feeling!
Are you in UK?
Halfords do two original spec Yuasa batteries Yuasa HSB053 or HSB057 they're both 48Ah 430A (I think these are original spec - someone correct me if not) - I was looking the other week, They have a 5 Yr guarantee.
They aren't cheap £100 so find someone with a Halfords trade-card. I think the only difference between them was was the position of the terminals..
Or there's Halfords own 45Ah - again the only difference is the terminal positions, but they're priced differently (£72 & £80 ) they have a 3 yr guarantee.
- Thank you received: 552
Been quiet again. Tax man ate my money this time.
Got a new battery, thanks for the tip. Went Yuasa in the end, like a new jimny!!
I also took him to get professionally blasted rust cured and undersealed after not liking the look of the underside when I got under, hopefully he lasts a bit longer now.
Next jobs, I need to do the kingpin bearings and add a shim to try and stop this darn death wobble! I also want to do a 2” lift whilst I’m at it, any tips on kits? It’s for occasional off roading for the mad places I go for work so doesn’t have to be the biggest meanest toughest kit.
Also also also, wheel spacers. I know they increase wheel bearing wear rate but I’m cool with that, any tips? What’s the max mm I can get away with without adding extra arches?
Thanks in advance!
- Thank you received: 653
32mm spacers with 215 wide tyres on standard wheels any bigger tyre will stick past original arch
Do these spacers look any good or is it worth paying the extra for the black raptor ones but they are only 30mm.
Cheers
Also what other jobs on the front axle should I be doing whilst I’m doing kingpin bearings and shims?
Cheers
- Thank you received: 1761
