Sheet steel
- Basketcase
- Thank you received: 51
- Thank you received: 650
Try local tip or scrap man. Local factories you just need an old filling cabinet or similar
- Basketcase
- Thank you received: 329
The steel i buy from a local steel supplier, 1mm sheet steel is what i use. Not expensive. and a 1x2m sheet would keep you in buisness for a long while. Just remember to spray the sheet with oil to avoid it rusting before you get to use it.
If I get better at welding i might go down to 0.8 thickness but i guess i would burn more holes if i do. But they say 0.8mm is easier to form into the shape you need.
Tried using scrap steel found in dumpsters behind car repair shops, but they tend to be so thin it is a pain to weld when you are not so good at welding..
However for the body mounts you should see what thickness is there allready. when doing reinforced places on the body I try to use same thickness but use a larger reinforced piece.
I try not to lay sheets on top of each other as that is the best way to make rust.
.Basketcase wrote: Any ideas what thickness I should use to repair/rebuild the body mount on the chassis? May as well tackle that while I’ve got the welder going?
I would say 3mm minimum for the chassis
That is most likely correct..
If you find scrap steel with a weld on it you most likely can weld it ok your self as well.
- Basketcase
- TomDK
- Visitor
- Basketcase
- Thank you received: 923
eBay -
With free delivery!
Or www.themetalstore.co.uk
Dave
Worth a PM ?
