BigJimnyMeet 2024
Ulysses
15 Jun 2019 16:49 #209990
Time for a little fiddling today after spending most of the day chasing problems on J999MNY (but thats another story!)
Repainted and stickered Trailmaster shocks/springs and brand new Trailgear HD steering bars on. Then problems with the old brake calipers. Had forseen this so ordered some from ebay coming from germany (a new pair for £96.69). To fit tomorrow...
Brakes are important so theres some nice new braided hoses to go on in the parts stash as well. Also have a rear disc kit in the stash ...
for this, which is starting to go back on as well...
And finally... My garage landlord has a side business with wagon tapaulin supply and repair. He got this made for the rear bed for me. The red is a bit bright, but it will look the part hopefully...
More tomorrow
More tomorrow
The following user(s) said Thank You: stiffsteve204me
- Thank you received: 1761
15 Jun 2019 17:07 #209992
16 Jun 2019 16:37 #210032
Back at the spanners again today. Got the new brake calipers on the front and new braided, extended and red lines on. Think I need to nip it up as it was weeping a bit on the connections to the old pipes (and bleed it all). Forgot a picture of that though
Onto sorting out the rear then.
Trimmed the old brake drum back plates off the rear shafts and cleaned them up. Popped back in a treat. Springs and shocks also nice and easy. Then the rear disc conversion kit out of the stash and onto the axle. Full braided hoses on as well and some nice stainless 'P' clips to hold the cross-axle pipe on securely.
Then the brake union on the chassis was rounded so it got cut off and a nice new flare made with this tool...
Also had a problem with a cold welded nut in the bush of the panhard rod so fished that out, spare one in and welded the adjuster (once adjusted) to stop any future problems.
Then it was wheels back on and down to the ground time. Front wings bolted down and front bumper fitted. Wheel arch plastics fitted also. Coming along nice. Cage and pickup body next time...
The following user(s) said Thank You: furo, stiffsteve204me
- Thank you received: 923
16 Jun 2019 17:42 #210034
Looking fantastic Riccy!
Can't wait to see it in the (tomato) flesh!
Dave
Dave
16 Jun 2019 18:11 #210037
22 Jun 2019 16:38 #210207
Cage back onto the body. Winch out again on J999MNY (about the only use it gets )...
and bolted down again with nice new fixings and locknuts everywhere...
but managed to scratch the paint on both front wings, because I was doing this on my own...
just as well I have a spare bottle of the red then
continued...
continued...
22 Jun 2019 16:42 #210208
as the cage went on nice and easy it was onto the tipper bed...
and side checkerplates with nice rebated fixings as well...
all coming together nice now..
still loads to do but at least when I sat back with a beer and looked at it today... its finally starting to look finished!
- stiffsteve204me
- Elite Member
- Thank you received: 151
22 Jun 2019 17:05 #210210
by stiffsteve204me
“He that strikes the venison first shall be the lord o' the feast.” — Shakespeare, King Lear.
Replied by stiffsteve204me on topic Ulysses
Looking good, Riccy.
Steve.
Steve.
22 Jun 2019 18:54 #210217
- Visitor
22 Jun 2019 18:58 #210218
Replied by Daniel30 on topic Ulysses
Looking really nice Ricky
23 Jun 2019 16:01 #210233
Thanks guys!
Day of pipes and hoses today. Specifically breather hoses for axles, transfer box and gearbox.
I had tapped threads into the axles and t-box when they were off, and the gearbox just needed extended. Pipes tie wrapped under the car with some loops for movement and routed up to the battery area. Smaller airlines are for the ARB air locking diffs.
Joined the breathers together and took two pipes out to stick out of the plastic below the windscreen, then up the snorkel. Convenient drain used to get the pipes up through the scuttle panel...
view from inside the wheel arch:
Then made a neat little plate to mount the air compressor and manifold on. Had to move the screenwash bottle so made a plate for that as well.
Then the final hose thing was the fuel filler pipework. Little bracket and it fits neatly enough...
Finally moved it outside for a wash. Very dusty so looks good. No brakes however so it was a bit tricky and nearly hit the landlords van
Really need to get the brakes bled and see whats causing the ABS light to be on next. Wire up lights and checkover for MOT after that
- stiffsteve204me
- Elite Member
23 Jun 2019 16:40 #210236
by stiffsteve204me
So good to see it outside.
Did the eyelids blink when they hit the sunlight?
Steve.
Steve.
Time to create page: 0.440 seconds
