BigJimnyMeet 2024
Ulysses
- Thank you received: 650
09 Feb 2019 17:14 #202861
Replied by jackonlyjack on topic Ulysses
I have no words
- Thank you received: 1754
09 Feb 2019 17:44 #202865
17 Feb 2019 17:40 #203348
And now for the back end...
Made up some bolt-on plates and a tube to link between the chassis rails and support the trailer body...
Then tried some 2 plane pipe bending. Unfortunatley the bender I have is unable to make bends close together by its design, so I did have to cut, sleeve internally and weld a section on the drop of the side bars, but its pretty good and certainly strong enough in the scaffolding pipe. The side bars weld to the roof hoop and to the rear bolt-on plates.
And the trailer body fits nice and snug on the brackets:
Decided a bit of bracing was needed so have started on some kickers from the roof down to the mounting plates.
Next will be finishing the other kicker and onto the rock-slider part of it. That will also need to be a bolt on fixing of some sort to enable the cage to be removable, but that shouldn't be too hard. Rocksliders are basically box section steel to run along the sills and have kickers back to the chassis for strength.
17 Feb 2019 17:50 #203349
- Thank you received: 305
17 Feb 2019 18:38 #203357
Pah, was too easy I guess. Points to you my friend
Yes it was interesting to have a search for '12v waterproof linear actuator'. They are essentially similar to a hydraulic ram, except they are all-in-one and generally are designed to run from 12v DC, therefore, much cheaper and easier to install. Wiring is simply reversed to get the same action back in. Runs at about 20mm/sec but will be faster with how it's to be mounted.
The one pictured is good for 4000NM force in both directions, more than ample for the tiny bed on this project
For the hinge point I have been looking at pillow block bearings from various engineering suppliers, these offer way more service life and lifting capacity than I will need, but are about £20ea for a simple block that can bolt on to the trailer body and allow it to swivel enough to work.
17 Feb 2019 19:45 #203361
by sniper
23 Feb 2019 18:14 #203722
Started bending more pipe to make the cage come over the roof and down the sides. Not too bad (apologies for the poor pics). More messing about tomorrow
23 Feb 2019 21:04 #203734
24 Feb 2019 17:55 #203767
Some pics in better light. Had to remake the passenger side bar over the door after ballsing up the gob cut onto the rear hoop
Finally got it on and happy enough with it.
Next was starting on the bottom rockslider bar part of it. Cut some 50x50x3 box to fit and trimmed the bits of cage sticking down. Some spot welding to allow me to shift it about for alignment. Made up some bent arms to connect that to the chassis with some large spreader plates for bolting onto the rockslider bars. Actually managed to get a half decent weld on one of them as well
Then a little bracket to attach to the original roof bar mounting points (well the front ones at least ). Nice thick bit of rubber cut and put under it as well. Pretty sturdy now. The cage will easily be strong enough to use as a jacking point.
still want to put a brace bar above the windscreen to link both side bars together, but need to do the rockslider bar and mounts on the driver side. Also thinking about a bar to come along the top of the front wings and connect to the bumper (brush bars).
- Thank you received: 923
24 Feb 2019 18:14 #203770
Good progress Riccy!
24 Feb 2019 19:57 #203782
Time to create page: 0.216 seconds
