BigJimnyMeet 2024
× Are you building a Mud Monster or a Pavement Princess??
Jimny Trayback
  • Riccy
  • Riccy's Avatar
  • Banned
  • Banned
  • J999 MNY Bashing around Carlisle
02 Jun 2019 18:13 #209486 by Riccy
Replied by Riccy on topic Jimny Trayback
No eBay APP ID and/or Cert ID defined in Kunena configurationBigger injectors coming? The blue are for the 1.6 I think?
Ive got some of these in the stash (but proper denso ones) ;-)
Did the swift AC take much fitting? and I see you have the swift/liana crank pulley there, does that relate to the AC compressor?
03 Jun 2019 08:06 #209528 by sniper
Replied by sniper on topic Jimny Trayback
I've been trying to talk Riccy into ITB's and a standalone ECU for an upcoming project, it will be good to see your Jenvey's on and running and Riccy is bound to get a bit of "Shiny thing" lust.....
What compression are you running Keith ?
sniper
03 Jun 2019 18:22 #209551 by Keithy
Replied by Keithy on topic Jimny Trayback
sniper wrote: I've been trying to talk Riccy into ITB's and a standalone ECU for an upcoming project, it will be good to see your Jenvey's on and running and Riccy is bound to get a bit of "Shiny thing" lust.....
sniper
9.0:1 matey.
Riccy and Jack could get their heads together and make a couple of sets up?
03 Jun 2019 18:29 #209554 by Keithy
Riccy wrote: Bigger injectors coming? The blue are for the 1.6 I think?
I used 220CC injectors on the M13A turbo... @25 PSI they were only at 53% duty cycle
If it needs to I have some 440CC ones I can put in......got all kinds of colours here lol
15 Jun 2019 20:46 #210005 by Keithy
Fridays job never happened so I took the opportunity to make the exhaust manifold flange.
Just need a turbo flange now.
Fitted the take off for the filter relocater and the oil cooler too.
06 Aug 2019 12:02 #211877 by Keithy
Finally after a full year I have it painted how I want it.....weather was against me last year after taking on the task of finishing a friends trayback.
Axles and chassis to start next.....once the interior is back together.
Made a cover for the roof aerials to keep it looking as if someone cares.
Trim panel from front of bonnet is maybe going to get a redesign for the new shape bonnet (GenIII Chopped)
  • Daniel30
  • Visitor
  • Visitor
06 Aug 2019 13:17 #211879 by Daniel30
Replied by Daniel30 on topic Jimny Trayback
Yummy ;) ;) ;) ;)
22 Nov 2019 10:20 #215860 by Keithy
Finally getting around to making the "Brazillian Job" snorkel......I think the GRP one is the one I'll go with.
Also checked the adaptor plate to fit the six speed gearbox....I need 2 of these one for each jimny.
I'll have to remember to use Al for it 20mm thick.
26 Nov 2019 20:27 #215991 by Keithy
Testing the snorkel fit against a wing....happy days!
  • Daniel30
  • Visitor
  • Visitor
26 Nov 2019 20:56 #215993 by Daniel30
Nice, that's proper nice ;)
  • Riccy
  • Riccy's Avatar
  • Banned
  • Banned
27 Nov 2019 17:35 #216020 by Riccy
Loving the snug fit snorkel!
Is it the toyota/lexus J160 transmission you are using?
I see the ratios are pretty similar to the R7me box, except 6th is where 5th is on the Jimny box. Kind of like an extra gear between third and fourth. It should help with acceleration, but I dont think it will do anything much for the top end speed.
There is a website I found with details about swapping in a Nissan 6th gear to lower the ratio...
"One modification that’s known to work well is to use the 6th gear-set sourced from the Nissan S15 AZ6 gearbox and fit into one of the Toyota gearboxes. The J160 uses originally uses a 0.869:1 ratio compared to the Nissan gear-set with it’s 0.767:1 ratio. This results in lower engine revs for the same vehicle speed during the use of the 6th gear."
from: www.sq-engineering.com/tech-articles/j16...-modification-guide/
If you are making adapters, would you be able to squeeze in a third for me? Pretty please? :whistle:
I am also in need of some of your newer front wheel arches next time you are at the vac former
27 Nov 2019 18:56 #216024 by Keithy
Not sure what a 160 is.....this has the same 5th as the jimny.....6th is higher.
Arches like these?
Get yer hand in yer pocket...
Time to create page: 0.267 seconds
Powered by Kunena Forum
