BigJimnyMeet 2024
Discreet but capable
- Thank you received: 651
03 Feb 2019 10:36 #202432
This is the first time i have put video on you tube
just need to figure out how you get them in one place pmsl
Jack
Replied by jackonlyjack on topic Discreet but capable
Jack
- Thank you received: 305
08 Feb 2019 10:10 #202795
by sniper
Replied by sniper on topic Discreet but capable
Just waiting on some castor correction bushes but springs, panhard bushes and 25mm seat are ready to be fitted next Wednesday.
The quality of the Eibach springs appears to be very high, I wish my car had such a sparkle in the paint, they are in equal length pairs so the thicker seat will be fitted on the drivers front.
sniper
sniper
- Thank you received: 1759
08 Feb 2019 10:23 #202797
Replied by Lambert on topic Discreet but capable
If they're equal length pairs just because they are taller doesn't mean that you're going to need a thicker spacer th level them. As in I think you're going to find 25mm is too much and will make it lean the other way.
08 Feb 2019 10:38 #202800
by sniper
The springs are all part numbered, rears are the same part number on each of the pair, same for the fronts. There won't be any bias across an axle, so chances are it will lean.
Yes, 25mm might be a touch severe, I see where your coming from...... but... I'm fitting the existing 15mm seats with the new springs and it will only give +10mm to the osf. I'm only 10st wet through, I think that will be enough to level it.
sniper
sniper
08 Feb 2019 11:03 #202802
So a total lift of like 65mm?
08 Feb 2019 11:08 #202803
Hang on I'm confused. You're wanting to have a 15mm spacer under 3 springs and a 25 under the other?
08 Feb 2019 11:44 #202806
by sniper
You've got it ish.......
15mm seats + 30mm lift springs = 45mm lift on three corners.
25mm seat + 30mm lift spring = 55mm lift on osf only.
sniper
sniper
08 Feb 2019 11:54 #202807
Ok that's clear. Do your dampers have a corresponding travel length to accept the longer springs or are you swapping those also?
08 Feb 2019 12:07 #202808
by sniper
Yes they are +30mm with +30mm bumps too.....
sniper
sniper
08 Feb 2019 12:11 #202809
I'd hate for it to rip itself to bits after all the effort you have in it!
09 Feb 2019 09:01 #202853
by Keithy
Replied by Keithy on topic Discreet but capable
RTV trial looks like fun.
09 Feb 2019 10:27 #202854
by sniper
It was a lot of fun Keith, a bit scary too...... It was a bit unnerving for poor old jack, it was his car and he was driving it home.
Some of the obstacles were very severe, one had a near vertical fall that swallowed a whole Discovery, it must have been a 10-12 foot fall. You did have the option to avoid it but still make the gate. Jack chose to go round on the lesser route (thank christ).
A really enjoyable day, I would suggest that all 4x4 owners go to one and see what their cars can do. Spectating is free.
sniper
sniper
The following user(s) said Thank You: Keithy
Time to create page: 0.189 seconds
