BigJimnyMeet 2024
KAP Suzuki Jimny - rebuilt for the road
- Gazguzzler
- Visitor
20 Jan 2017 17:20 - 20 Jan 2017 17:27 #177059
by Gazguzzler
Replied by Gazguzzler on topic KAP Suzuki Jimny - rebuilt for the road
Deleted corrupt picture
Last edit: 20 Jan 2017 17:27 by Gazguzzler. Reason: Corrupt picture - again
- Thank you received: 653
20 Jan 2017 18:31 #177065
Replied by jackonlyjack on topic KAP Suzuki Jimny - rebuilt for the road
try rotating the pick 90 degrees it works for me every time
Jack
Jack
The following user(s) said Thank You: Gazguzzler
- Gazguzzler
- Visitor
20 Jan 2017 18:49 #177067
by Gazguzzler
- Gazguzzler
- Visitor
20 Jan 2017 18:50 #177068
by Gazguzzler
Well not for me!
- the_goshawker
- Visitor
22 Jan 2017 18:44 #177167
by the_goshawker
Replied by the_goshawker on topic KAP Suzuki Jimny - rebuilt for the road
Top work
- Gazguzzler
- Visitor
23 Jan 2017 19:05 #177196
by Gazguzzler
Progress is a bit slow again, but conversion plate is in place
But unfortunately the rear crankshaft oil is little damp, so a new one is coming on Tuesday
and I'm replacing the tired water pump although James P had kindly put on a new timing belt - Top Bloke!
Hoping to get it in by the weekend.
Phil
Phil
- Gazguzzler
- Visitor
23 Jan 2017 20:50 #177200
by Gazguzzler
Arse, arse, arse, another delay.... The Jimny and Vitara water pumps look identical, since my Jimny one was brand new, I thought it would be a quick swap, which I did....I went to put the timing belt back on and it wouldn't tighten up, on closer inspection the cam bolt fixing is about 10mm closer to right on the vit one, meaning the timing belt wont tighten up and my brand new Jimny pump is useless. So off to Newcastle tomorrow first thing for a 2 hr return journey to get the correct pump. How can it be economical for suzuki to build two pumps with only a slight difference?!?
HACKED OFF NOW
Phil
HACKED OFF NOW
Phil
- Gazguzzler
- Visitor
25 Jan 2017 20:35 #177265
by Gazguzzler
In the last couple of days I sourced a water pump and fitted that and also changed the rear crankshaft seal (which was weaping slightly), refitted the flywheel and clutch, and threw the whole lot in to the engine bay! Easier said then done, the engine refused to line up, which meant it took me a few hours to get everything aligned and in, I was despairing by the end. For anyone else doing this by yourself, I would recommend removing the inlet and exhaust manifolds and taking off the engine mounts before even putting it near to the engine bay! So now begins the long job of connecting everything back up again and hoping it all works.
I wont even be able to drive it when its changed as the front wheel bearing has collapsed - so I'll need to fix that as well
Phil
Phil
- Gazguzzler
- Visitor
27 Jan 2017 20:00 - 12 Jun 2020 15:15 #177378
by Gazguzzler
IT LIVES
I had it running for a few minutes, and seems to be smooth running so far. I have stopped now with the engine conversion and moved my attention to rebuilding the front axle so I can take it for a test drive. I swapped the drivers side bearings, helped massively by having a 20T press. So next its passenger side, which should be fairly quick now I know what I'm doing. Then bolts the wheels on and get it out on the road to get properly up to temperature and look for leaks / issues.
Engine ready to install
Ongoing work...
Phil
Ongoing work...
Phil
Last edit: 12 Jun 2020 15:15 by mlines.
- Gazguzzler
- Visitor
27 Jan 2017 20:02 #177379
by Gazguzzler
Jeez, this software in doing my napper in....
1st pics was the engine ready to fit, 3rd pic was a new Rocklobster box.
Phil
Phil
- Visitor
28 Jan 2017 01:15 #177397
Replied by Daniel30 on topic KAP Suzuki Jimny - rebuilt for the road
Try photo bucket
- Gazguzzler
- Visitor
28 Jan 2017 17:59 #177433
by Gazguzzler
First proper test drive today, and it pulls like a train, what a difference, 5th gear is now usable. It was just a few miles to check nothing was leaking and let it get properly warm, but initial impressions are good, although I do think my 1.3 was very tired. Just a few small jobs to finish off now.
Both front wheel bearings are also changed, quite an easy job but owning a press makes a big difference.
Phil
Phil
Time to create page: 0.173 seconds
