Project Sink or Swim
- ZukracerV6
- Visitor
- Thank you received: 1759
- Visitor
- Amphibian
- Visitor
- V-350
- Visitor
- ZukracerV6
- Visitor
Amphibian wrote: Mine has air con - but not all the extra insulation you've put in or the extra fan, and it doesn't work terribly well as a result. It makes the air slightly less hot, rather than actually cool.
Can you post some pictures of your air con? I would be interested to see where the condenser and hoses have been fitted etc. Also does your Surf have a fresh air intake for the heater from the outside or does it just recirculate the air from the interior? I will try and post a few pics of the heater air intake.
- ZukracerV6
- Visitor
The fan is wired to run at all times when the engine is running to keep both the engine and engine bay cool.
- ZukracerV6
- Visitor
V-350 wrote: Awesome build!! Can you make some pictures from under the vehicle please?
Some cheeky bottom pictures as requested! Let me know if there is anything particular you want a good look at
Photo from the front looking towards the back
2nd photo from the front looking towards the back showing front prop shaft and the oil and water heat exchanger pipes (stainless steel pipes running on the right hand side of the hull)
Close up of the rear prop shaft and the oil and water heat exchanger pipes
Final shot from the rear looking towards the bow
- Amphibian
- Visitor
I'd let you have a poke around under the bonnet but I'm a bit of a distance from you.
I was never quite sure why the fan is always on. If you've cooled the radiator you've probably cooled the engine bay, haven't you? The problem being is that if you leave the ignition on for any time, perhaps to listen to the radio whilst parked, the battery goes flat.
A huge amount of heat that would normally escape under the car stays in because of the hull. A lot of this comes into the cab. The WWII DUKWs dealt with this by reversing the direction of the air flow. I think this would work on the Surf as you aren't fighting the natural air pressure as you move due to layout of intake. Actually, what would be ideal would be to have the direction one way in summer, sucking air out of the cab, and the other in winter, blowing hot air in.
- V-350
- Visitor
Keep up the good work, and please keep us posted with pictures!!
