BigJimnyMeet 2024
× Are you building a Mud Monster or a Pavement Princess??
2.0 HDI Lexus 6 Speed Conversion
  • OllieNZ
  • Visitor
  • Visitor
01 Apr 2015 18:52 #141777 by OllieNZ
Replied by OllieNZ on topic 2.0 HDI Lexus 6 Speed Conversion
Paul_sterling wrote:
OllieNZ wrote: I'm in Oxfordshire so a bit far away. Good luck with it. I'd like to see one for the 1.6 110 HDI engine, they cop alot of flack but 90% of their issues are due to their emissions control systems.
My C2 is powered by the DV6 (1.6 Hdi) 110bhp engine. had it 7 years, 80,000 miles since new (I bought it new) and it is brilliant.
Paul.
I hope yours doesn't have the same emissions control system as my 54 plate 307, they start playing up around 70-80k. I had mine mapped out, cheaper than fixing it and no future hassles.
Keithy wrote: A 1.6 16V? would have been fine....same bellhousing bolt pattern?
I should be outside making moulding boxes (flasks) Naughty aren't I
Afaik it's completely different to the previous generation hdi's
  • Paul_sterling
  • Visitor
  • Visitor
02 Apr 2015 06:59 #141790 by Paul_sterling
Replied by Paul_sterling on topic 2.0 HDI Lexus 6 Speed Conversion
OllieNZ wrote: Afaik it's completely different to the previous generation hdi's
very true Ollie,
the base platform for the DV6 was a joint venture between PSA and Ford, new from the ground up, so its not directly interchangeable with the existing 2.0HDi engines.
but, with a suitable bellhousing, it is a smaller engine, so fitting shouldn't be an issue.
the later Euro 5 onward versions are only single cam 8v, better useable performance, and a cleaner running engine, harder to dial out the aftertreatment system though.
Paul.
03 Apr 2015 20:58 #141862 by Keithy
Finished the moulding box for the bellhousing today.....it's huge! :D
Just behind it is the start of a lost wax pattern for an inlet manifold for a 950 V twin dirtbike...not mine sadly!
While the glue is drying on the box I finished another drawing for the turbo outlet as the existing outlet is for the transverse install in the Pug.
I have no facility at home for casting iron so I'll get the patterns finished and check the fit with an Aluminium pour, then drop the patterns off at a local foundry for casting.
  • Paul_sterling
  • Visitor
  • Visitor
03 Apr 2015 21:03 #141863 by Paul_sterling
Great work Keith!
Paul.
03 Apr 2015 21:24 #141866 by Keithy
Paul_sterling wrote: Great work Keith!
Paul.
Cheers Paul!
08 Apr 2015 20:37 #142131 by Keithy
Finally managed to try the pattern for the turbo housing.....Made a new one as I wasn't too happy with the original.
Pictures speak a thousand words so it starts on the router table and ends on the engine.
Just need to call at the foundry and then I can concentrate on the gearbox/ECU side.
After £150 on sand no more funds until next month.
The following user(s) said Thank You: Paul_sterling
  • Placek
  • Visitor
  • Visitor
08 Apr 2015 20:40 #142132 by Placek
Replied by Placek on topic 2.0 HDI Lexus 6 Speed Conversion
Wow, that's impressive!
  • Maze
  • Visitor
  • Visitor
08 Apr 2015 21:18 #142137 by Maze
Replied by Maze on topic 2.0 HDI Lexus 6 Speed Conversion
Very impressive the work you made so far!!!!!! ;)
09 Apr 2015 20:52 #142207 by Keithy
Cheers guys!
Plenty of stuff to do yet when time and funds allow :)
  • panosd
  • Visitor
  • Visitor
07 Jun 2015 13:29 #145595 by panosd
Replied by panosd on topic 2.0 HDI Lexus 6 Speed Conversion
You are the man. Keep on going.
07 Jun 2015 21:41 #145630 by Keithy
Just back from Strata Florida with the Jimny.....having a fantastic weekend of camping and laning=nothing getting done on this project!
The timescale for this project is to have the engine fitted and sorted by April next year in time for insurance renewal.
I have a couple of weeks in July where I'll be at home so expect some progress then.
21 Jul 2015 20:44 #148213 by Keithy
A little progress......I've got the turbo outlet back from the foundry.
Drilled and machined......I need to get the gearbox castings made and fitted so I can start the electrical work soon.
Not much free-time at the moment.
Time to create page: 0.159 seconds
Powered by Kunena Forum
