BigJimnyMeet 2024
- 1066Boy
- Visitor
10 Feb 2018 21:44 #189248
by 1066Boy
Replied by 1066Boy on topic Dave's "S200KYS" Jimny 'laner Build...
We cancel our events is its too wet. Most of our sites are farmland that is lent to the club so don't want too rip it up and not be asked back.
The topic has been locked.
- Thank you received: 1759
11 Feb 2018 04:26 #189255
That's a very responsible attitude if it's not your land or a dedicated site.
The following user(s) said Thank You: 1066Boy
- 1066Boy
- Visitor
11 Feb 2018 10:12 #189258
by 1066Boy
We have exclusive use of 6 private sites along the Kent/Sussex boarder. If possible we only use each one once a year (twice at the most) so the ground gets a chance to recover.
- Thank you received: 923
20 Feb 2018 12:37 #189519
Replied by X8GGY on topic Dave's "S200KYS" Jimny 'laner Build...
Just spent a couple of cold hours under and around the Jimny checking all the bushes, props, nuts and bolts, etc, jacked the wheels up one at a time and checked for bearing play, and checked the free wheel hub and ARB air locker operation at the same time, then checked all the fluids and ended up topping up the transfer box and engine oil a little...
All ready for another 'laning trip on Sunday then, more parts of Shropshire
Blog soon
Blog soon
20 Feb 2018 20:33 #189545
Bit of planned maintenance never did any harm!
23 Feb 2018 16:08 #189644
I fitted a new ZookBOB product to my own Jimny today - Anti-Roll-Bar 20mm Spacers
As predicted the droplinks have straightened out (a little, I may need some bigger spacers as I'm running 5" of lift, but you can see the positive effect of fitting these!)
Before -
After -
Chuffed
(I'm easily pleased )
Before -
After -
Chuffed
27 Feb 2018 14:19 #189727
Sunday saw us re-visit Shropshire, South Shropshire to be precise, and parts of Staffordshire...
Here's the blog - greenlaning.blog/2018/02/27/south-shropshire-milestones/
Enjoy!
Enjoy!
21 Mar 2018 12:58 - 21 Mar 2018 13:01 #190675
Bit of TLC before Sunday's greenlaning trip today...
New wiper blades so my co-pilot Alan can see where we're going!
And then an oil leak from the rear diff required my attention
Hmmm, it appears to be coming from the bottom two diff bolts that also hold the rear axle's diff guard in place?
So I decided to take the diff guard off for a look, partly as it was full of mud and I struggled to get to the drain plug, so I unbolted the U shaped brackets that held it to the axle and then the two bottom diff bolts, making sure to get a tub underneath to catch the oil that then leaked out of the two diff bolt holes...
I could then get to the drain plug to clean it all out and drain the rest of the oil from the diff...
Yup, the diff guard is full of mud...
(the puddle of oil is just what leaked out when I had the two small boats out to get the guard off)
So, I fitted two new bolts at the bottom of the diff after dunking them in some sealant to cover the threads, and then refilled the diff...
No leaks,,, Hmmm, I suspect the diff guard getting banged offroad has loosened the bolts on the diff, so I decided not to refit it... And then...
Took the front one off too...
Okay, some of my reasoning is due to a falling out with JimnyBits - I simply don't like his business principles, but won't go into details, so I've removed nearly all their products from my jimny - but also they just fill up with mud and reduce my Jimny's ground clearance... so they're off and in the for sale section of this fine site...
Just need to check all the other fluid levels and give the Jimny the once over and we're good to go...
Ah! And having serviced the cordless chainsaw, I've also ordered a spare chain for it
Last edit: 21 Mar 2018 13:01 by X8GGY.
21 Mar 2018 16:05 #190681
Oooh, I forgot... earlier in the week...
I fitted some bigger 'ZookBOB' (Me!) anti roll bar clamp spacers...
These are 40mm ones rather than the 20mm I originally made and fitted, so the droplinks are even straighter now -
I also fitted, whilst developing, a hand throttle -
It simply bolts to the bottom edge of the dashboard, and then when needed -
Folds down and you set the revs to whatever you want with the wing-nut equipped foot that sits on the accelerator pedal, thus keeping your Jim' ticking over at say 2,000 rpm to recharge the battery(ies) after a bit of winching, etc...
22 Mar 2018 17:45 #190745
Snap! This afternoons check round has shown the same problem from the bottom two bolts on mine
Replied by Riccy on topic Dave's "S200KYS" Jimny 'laner Build...
S200KYS wrote: Bit of TLC before Sunday's greenlaning trip today...
- Thank you received: 116
22 Mar 2018 18:00 #190748
by maverick
Jalapeño, IISY?
Replied by maverick on topic Dave's "S200KYS" Jimny 'laner Build...
I hope you and Riccy have checked your WINCHES, as we might need them up AND down Henryd!!
Jalapeño, IISY?
22 Mar 2018 18:04 #190749
bring it on
Time to create page: 0.282 seconds
