BigJimnyMeet 2024
02 Nov 2017 18:08 #185756
Replied by Riccy on topic Dave's "S200KYS" Jimny 'laner Build...
That looks to have the making of a bargain lift kit What shocks are you using to go with the +4" springs? I have in my mind ive seen procomp on there? Im looking at what to do for these Zanfi springs TomDK is tempting me with
Also do you have any issues with the rear shock rubbing on the panhard rod bracket (driver side i think)? Mines started with it since changing the arms to KAP corrected ones ;-(
The topic has been locked.
- Thank you received: 923
02 Nov 2017 21:18 #185770
Replied by X8GGY on topic Dave's "S200KYS" Jimny 'laner Build...
I had AVO shocks front and rear, but bent the rears when the radius arm / axle holes ovaled and the axle rotated and killed the rear shocks , so I've got AVOs on the front and ProComps on the rear...
- Thank you received: 1759
03 Nov 2017 06:26 #185778
Are the avo ones adjustable for compression and rebound or just rebound?
03 Nov 2017 06:41 #185779
Just the one knob?
03 Nov 2017 06:56 #185781
Ok cheers.
14 Nov 2017 15:07 - 14 Nov 2017 15:08 #186235
Little bit of TLC before Sunday's upcoming 'laning trip - Oldham to Holmfirth...
My Zanfi panhard bracket had started rocking on it's mount again... there is a fair bit of leverage on it though.
Found the 8mm bolts supplied with it had worked their way loose and were wobbling around in the slightly oversize holes, so I drilled them both out to 10mm and fitted new bolts and nylocs and then reassembled everything with new nylocs on the other bolts too...
And then I cleaned "Buzz" my cordless chainsaw! Not sure if he'll be needed on the run on Sunday, but he rides along in the back just incase...
Last edit: 14 Nov 2017 15:08 by X8GGY.
- petejones69
- Visitor
14 Nov 2017 16:53 #186243
by petejones69
Replied by petejones69 on topic Dave's "S200KYS" Jimny 'laner Build...
Looks really good.
14 Nov 2017 17:05 #186246
A clean chainsaw is a happy chainsaw.
15 Nov 2017 20:44 - 15 Nov 2017 20:45 #186299
Not really part of the build thread, but a milestone all the same...
My 50th Birthday today
Spent it in the garage making some more ZookBOB parts... Same again tomorrow
Last edit: 15 Nov 2017 20:45 by X8GGY.
16 Nov 2017 05:00 #186308
Happy birthday. Life begins at 50, says the 43 year old!
- 1066Boy
- Visitor
16 Nov 2017 07:02 #186311
by 1066Boy
Replied by 1066Boy on topic Dave's "S200KYS" Jimny 'laner Build...
Happy Birthday mate. Age is just a number, I am 47 but feel 60.
- Thank you received: 651
16 Nov 2017 16:30 #186327
Replied by jackonlyjack on topic Dave's "S200KYS" Jimny 'laner Build...
Happy Birthday Pal
Time to create page: 0.260 seconds
