BigJimnyMeet 2024
- Thank you received: 116
27 Jun 2014 15:21 #118778
by maverick
Jalapeño, IISY?
Replied by maverick on topic Dave's (Bits4Vits) Jimny 'laner Build...
How hard is it going to be to get the Hi-Lift out - isn't your drivers seat in the way?
I seem to recall that your drivers seat doesnt move forwards/backwards?
Just thinking, thats all .
Jalapeño, IISY?
The topic has been locked.
- Bits4Vits
- Visitor
27 Jun 2014 15:56 - 27 Jun 2014 16:02 #118780
by Bits4Vits
Replied by Bits4Vits on topic Dave's (Bits4Vits) Jimny 'laner Build...
Dead easy as it unbolts at the top with a wingnut behind the passenger seat that tilts and slides (my bucket seat is on the original seat rails so it slides, but doesn't tilt) and then just lifts off the base... will show you Sunday
There's more photos on the blog on my site that will give you a betterer view... Wll link them in later, on the iPad in the PO.
Last edit: 27 Jun 2014 16:02 by Bits4Vits.
- Bits4Vits
- Visitor
27 Jun 2014 16:35 - 27 Jun 2014 16:36 #118781
by Bits4Vits
Got rid of the postie!
Here you go -
Stainless wingnut top right just behind the tilt'n'slide passenger seat...
Then pull top of Hi-Lift out a few inches and just lift off the base with the 3 locating pegs -
30 seconds and it's out ready for use...
... same going back in...
It was too long to get anywhere in the back!
I've got a rubber bush under the wingnut to stop that end rattling, and the base is getting a 5mm sheet of rubber under the 3 pegs to stop that rattling too...
Here you go -
Last edit: 27 Jun 2014 16:36 by Bits4Vits.
- Bits4Vits
- Visitor
02 Jul 2014 14:35 #119181
by Bits4Vits
Missed working on the Jimny on Sunday as
we were out greenlaning
... again!
But back to it today for a bit...
Intermediary prop came by courier from Redacted (thanks Rich!) as the one I had was wrong... so lined it up and found it needed a bit of a spacer...
That's better!
Then the front and rear props -
Then out for a test drive, after going round checking everything was safe...
In fifth at 3,750rpm on the flat gives 60mph... ideal!... and the speedo is dead on against my iPad GPS Speedo App. This is with 235/75/15s with a Redacted Rocklobster box, and a 27 toothed speedo ring.
Then went to do some flex testing to make sure nothing rubbed...
Looks fine! No arch trimming needed it would appear?... this is with ORA radius arms that must position the wheels (axles) back into the middle of the arches perfectly... with 3" JimnyBits spring lift, and 235/75/15 tyres...
ARB Lockright and Compressor hopefully on Sunday...
Meanwhile it's in the tyre bay at the moment having the wheels and tyres balanced... then next door to the garage for them to, errrr, yes... ummm... fit my extended braided brake lines on... I don't do brakes!
That's better!
- gaz3359
- Visitor
02 Jul 2014 15:52 #119186
by gaz3359
Replied by gaz3359 on topic Dave's (Bits4Vits) Jimny 'laner Build...
Bet it feels good to give it a test run after all the work you have done so far. Looking good !
- Bits4Vits
- Visitor
02 Jul 2014 16:43 #119188
by Bits4Vits
Thanks Gaz, yes, good to be out driving it, albeit on the tarmac for now... more looking forward to trying it offroad... July the 20th in the Lake District!
gaz3359 wrote: Bet it feels good to give it a test run after all the work you have done so far. Looking good !
- funkyjimny
- Moderator
- 2004 jimny soft top, factory hardtop, ARB bumper
- Thank you received: 56
02 Jul 2014 18:07 #119202
by funkyjimny
Replied by funkyjimny on topic Dave's (Bits4Vits) Jimny 'laner Build...
Lucky with the tyres Dave, maybe because you don't have much offset on those rims ?
Gary
Gary
- Bits4Vits
- Visitor
02 Jul 2014 19:04 - 03 Jul 2014 08:24 #119212
by Bits4Vits
Luck?!
"Planning" you mean?!
We discussed the ultimate tyre and gearing combination at great length on this very forum somewhere...?
It was my quest for good on-road gearing and not too much fitting hassle that lead me to 235/75/15s...
That and the fact I already had them on the Zukhini Vitara, for the same reasonings...
Well chuffed!
Well chuffed!
Last edit: 03 Jul 2014 08:24 by Bits4Vits.
- Jimny_Aus
- Visitor
02 Jul 2014 22:56 #119237
by Jimny_Aus
Replied by Jimny_Aus on topic Dave's (Bits4Vits) Jimny 'laner Build...
not a huge fan of the wheels, but looks like you've built yourself a strong jimny,,,, some nice suspensions under it too..
- Thank you received: 252
03 Jul 2014 06:13 #119238
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Dave's (Bits4Vits) Jimny 'laner Build...
It's had a lot of thought put into it. A nice job Dave.
Grey pick up Jimny
- Bits4Vits
- Visitor
03 Jul 2014 06:54 #119239
by Bits4Vits
Thanks guys
As above, the wheels and tyres came off my previous vehicle as the tyre size suited this new build... the wheels are old strong alloys off a Vitara, and are the right offset as mate Gary said above... and they're silver so match the theme and original panelling on the bottom of the vehicle... An ORA rear bumper and sill protection bars are on their way, bare steel again so that I can get them powdercoated in Silky Silver locally to get a reasonably close match... So the wheels will have to do
Thanks James (j999pre), yes, thought about ths build a lot, before and during... this is to be my last project so I want it 'right', visually and mechanically... after this build I plan to 'lane one Sunday a month, maintain another Sunday a month, and... spend the other two Sundays relaxing and spending time with the family, dogs, DIY, etc, etc... Slow down a bit, now I'm the ripe old age of 46!
- Flameboi201
- Visitor
03 Jul 2014 18:39 #119255
by Flameboi201
Replied by Flameboi201 on topic Dave's (Bits4Vits) Jimny 'laner Build...
Looks grate mate . Proper job
Time to create page: 0.203 seconds
